Skeemid, joonised, raamatud
Manks
Re: Skeemid, joonised, raamatud
Postitus Postitas Manks »
Viimati muutis Manks, 11 Okt 2013 07:36, muudetud 1 kord kokku.
Vahetusfond:
Skeemida ja muu staff hea, aga ei näe lugeda mitte midagi ...
mina näen kl väga hästi lugeda.
Nüüd head suured pildid ja tipptopp lugeda :beer
Manks
Netis kolades leidsin venekeelset kirjandust. Ehk pakub kellelegi huvi ;)
http://varstu.planet.ee/mosse/Vene%20kirjandus/
Vahetusfond:
Manks
Tagumiste pidurisilindrite
erinevused:
Viimati muutis Manks, 20 Nov 2013 15:05, muudetud 1 kord kokku.
Vahetusfond:
need ei ole pidurisuppordid vaid silindrid. piduriSupport on midagi muud.
HendrikR
Telefon: 56643745
Postitus Postitas HendrikR »
Lõpuks leidsin ka 2141 "arusaadava" skeemi. :) Tähendused on Google translates tõlgitud. Sorry about that. :smokin
1 - side indicator,
2 - Front turn signal;
3 - head lamp;
4 - fog lamp;
5 - beep,
6 - light and dipped beam headlights;
7 - dimensional light bulb head lights,
8 - socket;
9 - Sensor control lamp oil pressure,
10 - generator,
11 - spark plugs,
12 - the ignition distributor;
13 - the gauge indicate the engine coolant temperature,
14 - the start of electric sensor,
15 - the blower;
16 - door switch lampshades;
17 - motor washing
the windshield;
18 - warning lamp switch hydraulic brakes,
19 - ignition coil;
20 - the backup light switch,
21 - starter,
22 - solenoid valve,
23 - Battery;
24 - hood lamp switch;
25 - hood lamp;
26 - microswitch;
27 - control EPHH;
28 - wiper;
29 - Fuse and Relay;
30 - safety;
31 - Relay include fog lamps,
32 - relay flasher and alarms;
33 - relays sound;
34 - wiper relay;
35 - the start of electric relays,
36 - relays tailgate window heating;
37 - relays low beam headlights;
38 - relays beam headlights,
39 - electric heater;
40 - resistor electric heater;
41 - lighter;
42 - cover the glove box lamp,
43 - microswitch;
44 - heater switch;
45 - wiper switch and windshield washer;
46 - column switch,
47 - signal switch lamp;
48 - lamp fiber heater control levers;
49 - retarder;
50 - Instrument cluster;
51 - fuel gauge;
52 - warning lamp fuel reserve;
53 - switch the alarm,
54 - switch tailgate window heating;
55 - warning lamp direction indicators;
56 - warning lamp turn marker light;
57 - warning lamp include high beam headlights;
58 - warning lamp closing choke carburetor 59 - warning lamp warning device and hydraulic brakes Handbrake brakes;
60 - warning lamp oil pressure;
61 - fog light switch taillights;
62 - headlamp switch;
63 - switch outdoor lighting;
64 - voltmeter;
65 - fog light switch;
66 - the ignition switch;
67 - Brake light switch ,
68 - lamp switch handbrake;
69 - fuel gauge,
70 - the luggage compartment cover,
71 - coolant temperature gauge,
72 - Room Lamp,
73 - tachometer,
74 - lamp lighting devices;
75 - reset button daily run;
76 - signal lamp switch closing choke carburetor;
77 - Speedometer
78 - ekonometr;
79 - tokoobogrevaemoe glass;
80 - horn switch,
81 - Indicator lamp rear light,
82 - dimensional light bulb rear light,
83 - Brake lamp;
84 - the backup lights,
85 - lamp fog light rear light,
86 - tail lamp,
87 - number plate lights
ALLIKAS: http://www.autoprospect.ru/azlk/2141-moskvich/
